Då har jag också lärt mig något nytt idag [emoji106] [emoji2]
Skickat från min SM-G800F via Tapatalk
Axelguide Chevrolet, GM m.m
Re: Axelguide Chevrolet, GM m.m
Fikk masse god info fra et Amerikanskt forum her:Grottulf skrev:Då har jag också lärt mig något nytt idag [emoji106] [emoji2]
That is a 60-1SU. Pretty cool axle.
It should have 3.5" tubes, a smooth bottom so it will slide over rocks easier, 32 spline axles, 70 sized wheel bearings and spindles meaning it should accept 35 spline axles, and from my understanding everything else should be standard 60 size as far as pinion/carrier bearings, gear sets and pinion seal.
Here is a little reading to get you started on it. I would definitely do some homework on it because it is a bit different than a standard 60.
http://www.bsfab.net/?p=18" onclick="window.open(this.href);return false;
92 Ford Explorer på 35" STT's
